sam3003
Hi there,
I have a C220 2014 which I had for almost 4 years.
During the last year or so, I have had to take it more than 10 times for the EML and MB did nothing but guessing so I eventaully toke it to an indie
Mercedes replaced the nox sensors two years ago under warranty and when it was out of warratny the indie recently said that it needed a new adblue pump and I opted for a used one which was fitted last month.
The EML came on again shortly after the pump was replaced and I was told that a full diagnosis was needed as the problem had to do with SCR. (I don't even know if the indie fitted a faulty pump as I just go by what he said)
I have done more than 100K with no major issues apart from the EML.
After doing the visual inspection last year, MB identifed the following issues:
1- Front brake dics becoming lipped (£560)
2- Rear brake discs worn, pitted and corroded (£502)
3- Rear coil springs corroded. advised to replace 2 if one breaks (£558)
4- Extremely noisey timing chair on start up (????) The indie said I am ok to drive it till the noise lasts longer
If I sell the car now, I might be able to get between £5500 to £7500 and buy the E220D ( 18 to 22K)
The car drives fine and I am able to get 55 to 60 MPG as I mostly drive it on the motorway.
My question is:
Am I better off selling my car and getting a E220D 2017 or 2018 with less than 50K on the clock and get mercedes extended warranty for peace of mind then sell the car just before the last warranty expires, or shall I keep my car and fix all the issues (£0000) !! and hopefully the car will service me till 250K?
I am really confused and cannot decide
Any help would be appreciated.
regards
My question is:
regards
