Bassmonster
Hi all,
I'm hoping someone can shed some light on this.
So about 3 weeks ago, my engine coolant sign came up on my dashboard. Not thinking much of it, I filled it up. After driving for about an hour, the next day, i noticed that the coolant sign came back again.
My usual mechanic was very busy so after doing a bit of googling, I decided to find the leak myself by using a Green dye and UV light. However, I found nothing. I then took that car to a garage, he did some kind of pressure test and said that my coolant system was OK and no leaks. He then checked the engine Oil an said it's not totally black like how it should be and said it was runny and said the head gasket has gone. My knowledge is very little when it comes to cars but he said the most common sign of head gasket going is white goo around the engine oil cap but there's no white goo whatsoever. I then took the car to another garage who said he cannot rule out the Head gasket going but not 100% sure.
There's no visible signs of water leaking in the engine but it does seem to be going somewhere.
The last thing I want to do is to spend a of money on getting the head gasket repaired only to find the problem still persists.
Any ideas as what could be causing this issue?
The heater, AC, works just fine and engine not overheating despite losing coolant. However, this is based around 45 minutes of driving or so.
I don't notice any loss of power as such either.
so the coolant loss is maybe around a 1 quarter of a litre after driving around for about 45 minutes or so...
