Sep 22, 2023 #1 S SwissToni New Member Joined Dec 29, 2022 Messages 2 Location West Yorkshire Car C180 Coupe Can anyone tell me where the coolant level sensor is on a 2014 C180 1.6 petrol engine (38000mls). The coolant level warning keeps appearing despite the level being ok. Many thanks.
Sep 22, 2023 #2 KennyN MB Enthusiast SUPPORTER Joined Sep 21, 2014 Messages 2,519 Location Paisley Car Me - BMW 440i Coupe / Dog -Cayenne Normally they are located in the expansion tank , if you see an electrical connection on the expansion tank that is normally it. They are paddle float switches so maybe it has stuck in the down position if the tank has run dry at any point ? K
Sep 22, 2023 #3 OP OP S SwissToni New Member Joined Dec 29, 2022 Messages 2 Location West Yorkshire Car C180 Coupe KennyN said: Normally they are located in the expansion tank , if you see an electrical connection on the expansion tank that is normally it. They are paddle float switches so maybe it has stuck in the down position if the tank has run dry at any point ? K Click to expand... Thanks I'll check that, it must be something like that because it's intermittent and the warning isn't permanently on.
