D
Deleted member 134751
Guest
I had some tyres replaced at my local MB garage earlier this week and within 10 miles of driving away, I get a red warning on the dashboard that says “Coolant Stop Vehicle Switch Engine Off”.
I was surprised because I believe they also normally do a ‘health check’ on the car whenever you have it in for work, so would have thought a lack of coolant would be identified.
Anyway, I left the car for a few days as I was out of town and I checked the coolant level this evening as the engine was cold and on a level surface. It was dark at the time so a bit hard to tell but it looked like I was filled up to the right level. I will check again in the morning to be sure.
I have also noticed that the temperature gauge on the dashboard goes right up to the max (120) even after driving 1 mile. The fans also kick in and they stay on for at least 10 minutes after switching the engine off (I have never noticed my fans on like this before).
There are no dashboard warnings when the key is in position one. And when it’s in position two, the only warning is the red coolant warning. Acceleration also appears to be sluggish.
Can anyone suggest what might be the problem here? Could it be a sensor issue, and if so, how much would I be looking at to have it replaced?
And will it be ok to drive about 5 miles to the MB garage? I am pretty skint at the moment and I am worried about damaging the engine.
Thanks for any advice
