Well it tells you the capacity and CCA values.I've managed to shrink the file, does this help?View attachment 136367
You are welcome.Thank you, will check when I get home, much appreciated.
Try your local mb commercial dealer - same battery as my c63Need a replacement battery for the above and not sure which size it needs as websites show two or three sizes and can't see side of battery to check. Took a picture of label on top of battery but says too big to upload here.
Seems reasonable.Measured it roughly and it's around 35 to 40cm. Rang MB commercials and offer was £140+VAT.
The Tayna site doesn't seem to have the exact code on my battery listed.
Buy it.Measured it roughly and it's around 35 to 40cm. Rang MB commercials and offer was £140+VAT.
You need to accurately measure all parameters.Measured it roughly and it's around 35 to 40cm. Rang MB commercials and offer was £140+VAT.
Far too logical surelyYou can measure the battery and compare that against the dimensions online surely?
Normally the battery model number is printed on top eg "096" "019" etc.
My E320 CDI uses the 019.
Cheap rubbish get the mb one they last 10 plus years.![]()
019 Hankook SMF Car Battery 12V 100AH MF60038
MF60038 Hankook Automotive SMF Battery Hankook are a pioneer in the battery industry and have been for the past 75 years. Challenging the quality and quantitative growth of the battery industry. Based in Korea, Hankook has a global network that has been strengthening its distribution...www.tayna.co.uk
Presume this is ok? in response to the post about measuring all dimensions, I can't get enough access to do that.
