TedMartin
Hi all,
I recently had a problem with my rear tyres, cheap ones, which I sorted out by fitting two of renowned names. The problem was that the ESP warning was coming on due to the bad condition of the rear tyres. Really bad condition. They were deformed! This as I said has now been fixed. I have now noticed that when I engage the cruise control at say 130Kph., it switches itself off. It doesn't do it at lower speeds. I've been advised about same size tyres and also brake light switch. I can vouch that the tyres are all the same size, which points to the switch. Is there anything else I should check? Is this a common problem with the W211?
Thanks.
Thanks.
