I'm having problems with a partially charged starter and had a critical warning the other day. I may need to get the battery replaced under warranty. In the meantime, I plan to get a charger. The CTEK MX 5.0 seems to be the one that people recommend, and I don't particularly wish to fork out almost 3x as much for the MB OEM one, which I believe is a rebranded CTEK anyway.
Looking at the CTEK MX 5.0 user guide, the first cycle is a desulfate one, which uses 15.8v. The MB manual has dire warnings not to exceed 14.7v charging voltage.
So using this charger would violate the express warning in the manual not to exceed 14.7v.
Is there a better charger to use, one that does not go above a 14.7v charging voltage?
