Righto, here we go
We start with our good old W212 centre console, with the sliding cover back as far as it will go, to expose the 12V socket, with it's pesky cover....
I have discovered you can rotate the cover, and it has "notches" every 45 degrees, but basically you want to rotate it 90 degrees to the right, so the hinge is at the bottom, thus:
Now we bring out the custom weapon - a 3D printed stand. 81mm diameter and 35mm high....printed by my friend who has two 3D printers. In black of course! Here is the side view, which shows two cut outs for cabling...
And a better view, which shows the larger void to stash some cable
Here is the stand in place. It keeps the spring clips up, and they hold it in place....
I've then added an
Aukey Usb Car Charger Dual Port 24W Flush Fit Car Adaptor, which is small enough that the 12V cover can still close when it's in situe, if nothing is plugged in. The reason I bought this is because is has two USB sockets, and when you use the lower one, the protruding bit of the USB cable is still low enough it doesn't foul the sliding cover...but still keeps the 12V spring-loaded cover open
I've also used a
25mm right angle USB connector (LEFT USB angle). I actually got this wrong, and should have ordered the RIGHT USB angle, as I wanted to use the left cup holder, but either way, it works in the right one.
As you can see below, the cable fits in the channel where the sliding cover goes - but (with a bit of sticking material) is kept left enough that it doesn't foul the runner
The cable drops into the cup holder and into the foremost cutout on the stand, and then can loop backward in the void, and up from the rearmost cutout, to route into...
...the last bit of kit, that is a
low profile USB-C desk charger, which fits in the cup holder, on the stand. I've added some more sticking material on the back to stop it lifting when I pull the phone off it, and it's good!
...and here we are with the upper half of the slider closed. Minimal cabling on show. If I could find a USB-C connecting cable that dropped straight down, I could have amended the design a bit, but they were all >= 1 M long, and that's not going to sit anyway tidily!
The key objectives were that the sliding could still function and close fully without fouling the cable OR the protruding USB connection. Snug!
And last but not least, with the phone plugged in. Mission accomplished.
Printed Stand : £4.00 (for plastic material)
Data Cable : £4.50
Charger Dock : £9.99
AUKey 12V socket adaptor : £11.37
Total cost : £29.87
Not bad for a mostly tidy bodge
Can now just get in the car, plug phone in, drive off, and grab it when I get out, and hide it all away
