Diesel injectors
carlh2269
c220cdi
I have removed 2 injectors, to include the feed pipes and connectors.
Once everthing is cleaned, reassembled and reattached do I need to bleed the injector feed pipes before the engine fires up?
Or is it a case of keep turning the engine untill it fires up?
I'm not sure if an air blockage can occur whilst its been apart.
Just reconnect and keep cranking, it will eventually start
bob
sorry for not getting back to you earlier but have only just had spare time to work on the car.
Anyway I took your advice and eventually, after recharging the battery, the car started.
Many thanks bob.
