haydar
Hi guys
I need some help.
I've got a 220cdi w211 which has covered some 100k miles. Now when I start the car for a few seconds the engine note is perfect, but then it suddenly hardens and gets louder. It's almost as if there is a slight diesel knock.
Now over the last few months I've changed the following:-
i. New main drive pully
ii. New belt tensioner
iii. New auxiliary belt
iv. New water pump
v. New injectors
vi. New MAF
vii. New EGR valve
viii. New valve seals
ix. New turbo
I'm now kind of running out of ideas, what could be causing the problem. Once the car revs rise over about 2k rpm it all quietens down.
My question is does anyone know what could be causing the hardening of the engine note. Like I said, when the car is started for a few seconds the engine note is beautiful, but then suddenly it hardens!! Is there something that turns on at this time that can be causing this?
The cars performance is fantastic and it is noticeably quicker than other 220cdi here!!!
Here is a wav of the engine sound sound.wav
This is the car starting first thing in the morning. The was was in a large garage and I was standing over the engine with the bonnet open.
The car changes note regardless of it being hot or cold, but it sounds more prevalent was cold. The oil used in the car is mobile 1 fully synthetic.
I guess my question is that the noise changes after a few seconds of startup. What could be making that happen.
Here is a wav file of the car when it's warmed up with the bonnet closed sound2.wav
I need some help.
iv. New water pump
v. New injectors
vi. New MAF
vii. New EGR valve
ix. New turbo
