Mar 20, 2011 #1 J Julieawards New Member Joined Mar 20, 2011 Messages 1 Car Mercedes ML320 How do i know if my ML320 has a diesel particle filter?
Mar 20, 2011 #2 S SKIPPERDOG Member Joined Feb 14, 2011 Messages 57 Location dublin Car 211 320cdi you could ring a merc dealer give them your chassis number parts should be able 2 you from your data card .or you could look at the cat there will be 2 metal pipes coming out of the cat going to a pressure sensor if it has dpf fitted
Mar 20, 2011 #3 alibally Active Member Joined Jun 8, 2008 Messages 219 Location edinburgh Car W169 A160 and Smart 451 The vehicle data card will have code 474 on it if it has. Normally they are not fitted to ML320 cdi's but a quick phone call you will know for sure.
