Dietz IMU Paket DVB-T MERCEDES Comand APS 2.5
axesrus
HULL
S500 W221 BLUE
Anybody ever fitted one of these...experiances?
star coding etc?...for a w220 2002 s500...digital tv .
A package for fitting the dietz DVB-T tuner on a Mercedes Comand 2.5 navigation system.
The DVB-T tuner is controlled with the keyboard of the navigation system and/or with the IR remote controle.
Content:
• Dietz DVB-T tuner 1491
• Dietz Multimedia Interface IMU(R) CAN Art.1451
• cable kit 1471
• cable kit to DVB-T tuner Art.1478
DVB-T Tuner 1491
This unit is equipped with two tuners working completely separated from each other, while delivering a sufficient and immaculate picture - even when used at higher speed!
This is achieved with the "True Diversity" circuit, where only the respective strongest signal will be passed through for further process.
Switching between the tuners is done rapidly and unseen in the background.
• True Diversity double tuner with IR remote control.
• 5 integrated games for additional entertainment.
• 2x F-jack.
• External remote control connector - prepared for use with IMU® 1451 & 1550.
• PAL/NTSC suitable.
• 2 x AV In (RCA).
• 3 x AV Out (RCA).
• 1 x Stereo Audio Out (RCA).
• 4:3 / 16:9 optional screen format switching.
• Frequency Range for: VHF 174MHz-230MHz, UHF 47-860 MHz.
• 6/7/8 MHz Bandwith support search.
• Extrem platzsparendes Design für den einfachen Einbau (LxBxH): 214 x 185 x 36 mm.
• DC 12 V connector.
• Delivery includes 2x active antenna
• the provided active antennas are waterproof - therfore can be mounted very well at the vehicles outside.
• Manufacturer: Dietz.
• Prod.Nr.: 1491
IMU(R) CAN (Intelligent Multimedia Control Unit)
Enables to connect the DIETZ DVB-T tuner to an OEM navigation system.
• IMU = Intelligent Multimedia control Unit
• The head unit's buttons can be used to control the connected device
• e-certificate ECE R 72/245 and 95/54 existing
• Dietz Prod.Nr.: 1451
cable kit to DVB-T tuner for IMU:
• Equipmentspecific cable kit
• to control an DVB-T tuner 1491
• by the buttons of OEM monitornavigation
• Dietz Prod.Nr.: 1478
cable kit Comand 2.5:
• cable kit for Multimedia Interface 1451
• Dietz Prod.Nr.: 1471
Compatible with / Compatible avec / Kompatibel mit / Compatibel met / Compatibile con / Compatible con:
• MERCEDES (CL-, S- Klasse / Class) Comand APS 2.5 (Blaupunkt-Systems)
• Baujahre/years of construction 1996 - 09/2003
I see you got this fitted in the end, how are you finding the S class to drive a couple of months in?
Its proberly the best car I have Ever driven, I'am no petrolhead. But i do like that on tap power, the 5ltr V8 delivers. (its one of those cars you don't drive fast or aggresive, as you and most others know the powers there if required. nobodys had a pop at me, at traffic lights yet).
Its got a big feel to It..which you soon get use to. and comfort/ride quality is very good.
I have a similar type of package with multimedia interface and DVB-T with related cable kits. In the cable kit between MMI and Comand, there are two wires, one blue and another yellow, which I suppose need to be connected to Comand ? Any idea what these wires are for and where they need to be conneted? There were no installation instructions with the kit.
http://www.carlights.de/multimedia-interface/dvb-t-tuner-fuer-mercedes-comand-25.html
And the car is W220 S320 CDI MY2001 equipped with option 862
