Different tread depths same axle??
moog999
E350CDI S212
May have a puncture in an unrepairable spot on one of the rears. Grumble.
Both tyres current have about 4mm left.
I just happen to have a part worn bridgestone with about 7mm left.
Will that sort of difference be detrimental to the rear diff do we think? Probably a difficult one to answer but worth an ask.
That’s what differentials are for.
A 3mm difference in rolling radius is just the equivalent of a passenger sitting in one side of the car surely.
Just to confirm the tyre you will be replacing is also a bridgestone? Remember only identical brands/tread patterns on the same axle.
1% difference in diameter shouldn't be anything to worry about.
Cheers, yes same tyre as is already on.
I'll get it swapped over then!
