Do any OGs know what this old workshop tool is for?
robparker
taunton
c55/115d/fintail
Any ideas what this was used for? I can't find that part number anywhere online.
Wonder if you could search the part number on WIS?
Isn't it for holding the bolts when taking apart the top end?
Hmm could be, there is a whole bag of those metal pins, similar size to headbolts.now you say it, but I don't know what they'd be needed for
Each pin will have a slightly different diameter, which should be stamped on it.
Something similar to this:
Same principle as a feeler gauge, but for round holes.
Are the pins stamped or marked in any way then?
If it was an engine service tool, I’d expect the part number to have an engine-type specific/related part number rather than a chassis-specific code? :)
Eg 119, 120 etc rather than 140 prefix.
W140? It could be a tool for measuring anything, not necessarily engine component? E.g. ABS (for example)?
Looks like a Mercedes cribbage board
Yes there are markings on them, the feeler gauge-type-thing could be true.
Some workshop tools do have a "w140..." Prefix, like the hooks to pull out dash clusters, even though they are made for most models, not just the 140
Yes plenty of tools have a chassis-type prefix on them, just that engine tools generally have a prefix relating to the engine type instead :)
As you say the cluster tools have a 140 prefix as they’d have been made originally for the 140 clusters when they first came out :thumb:
