Does it do miracles?
noogieman
EU
I Loewe Old Skool AMG
I bought this can of Normfest Viro AC Freshner from ECP.
Did anyone test this product?
Any guud results from this product, do you recommend it for use?
Dose it give a good fragrance inside cabin when sprayed into vents?
If by miracles you mean achieve world peace then no. If you need to disinfect your HVAC because it smells musty then it works. I use this once a year on both cars and it works. It leaves a bit of citrus smell but that soon goes. It is primarily for disinfecting the ducts but also works if you put the HVAC in re-circulation mode.
If you have a real problem with a smelly HVAC then a one shot disinfectant (Normfest make one) or better still an ozone generator works - but you have to use these with care because ozone is dangerous if not used and vented properly.
no i don't have a smelly HVAC.
all HVAC system has bacterias and will eventually smell funky.
i bought this solvent coz it was cheap on ECP, only to test it.
i want to be sure it's perfectly safe to use by asking on MBclub before I start spraying my vents.
do i stick the plastic pipe all the way in and then slowly pull pipe out while i spray richly inside vents?
how often should this be done?
once or twice a year to prevent funky smell?
