Right well i came across this on the W126 mailing list.
COMPLAINT DESCRIPTION:
After engaging shift selector into reverse gear position, transmission seems to momentarily freewheel during throttle application. Reverse then engages with harsh engagement quality.
Now my SL has always done this when going into reverse... my SEC does it but not as harsh.
Ive always just thought it was a characteristic... it has never got worse and many older MB's that ive owned have done this... So never thought any more until i read this post...
The american guy that posted this says the solution is
This sounds like it could need a different intermediate plate. My '88 420SEL had the same problem and this fixed it right up. The car probably had this problem for seveal years before I acquired it, now has only 80k miles, and the car showed lots of signs of missing recalls and updates and maintenance. The new intermediate valve body plate P/N is 140.277.14.14, its about $100. Need to block off one hole in the new plate and reinstall. Transmission doesn't need to be removed, just the valve body. Alldata has the procedure,
Now before i go taking my auto box apart, has anyone heard of this and do you think i should bother... My SL does less than 2K miles a year.
Is this even something to be worried about?
