Look behind the door seal rubber where the handle is , there wil be an acess hole into the door , on the front doors it will be to the back of the handle , and on the rear doors it will be to the side of the handle .
There will be a TX 20 screw located here , this will release the end peice of the handle, then the handle will slide back and out .
On the driers door there will also be a small wire to unplug along with a shaft for the door lock
