OneForTheRoad
- Apr 20, 2015
- Location
- uk.
- 2024 Audi sq5 - 2019 Glc coupe 350d was 2017 e350 c207 .. +65 ford kuga 2.0 cdi zetec awd..
Is it using ad blue ?
NopeIs it using ad blue ?
So it did actually go higher pre regen it did go to .29 on Icarsoft bar reading and slightly higher so 290 millibar on hard throttle so definitely an increase on pressure pre regen - don’t know if that is blocked, regen is running fine like I say but it it literally every 50 milesNo codes. The only code pre regen was related to DPF full, no other codes after I swapped the sensor.
I don’t believe the dpf sensor reading is any different pre regen but I’ll check tomorrow when it does yet another regen !
So it did actually go higher pre regen it did go to .29 on Icarsoft bar reading and slightly higher so 290 millibar on hard throttle so definitely an increase on pressure pre regen - don’t know if that is blocked, regen is running fine like I say but it it literally every 50 milesIf it's still only reaches 80mbar that's too low to be restricted. Does soot load in g suggest anything different?
It's always shown as gauge, so 0.65bar would be less than atmospheric? How does that happen?
By design or mapped out ?Nope
Design - the car does have a DMS remapBy design or mapped out ?
I would just gut the dpf out..Design - the car does have a DMS remap
Yes, 0.65 bar gauge pressure is less than atmospheric pressure. It happens because the pressure measurement you see is relative to atmospheric pressure, not the absolute pressure.If it's still only reaches 80mbar that's too low to be restricted. Does soot load in g suggest anything different?
1.01 bar is sea level , so not sure where this guy parks his carYes, 0.65 bar gauge pressure is less than atmospheric pressure. It happens because the pressure measurement you see is relative to atmospheric pressure, not the absolute pressure.
Old man Diesel must be spinning in his grave at what they have done to his relatively simple clever invention.
Time to have his dpf gutted.A mate of mine has just had to spend £2k unblocking virtually everything on his Toyota because he has a diesel and never does long trips
.....and muttering in a rather clattery way.....but at very low revs...and very high torque!![]()
