Hi
So my DPF woes. I had the dreaded EML light come on a couple of months ago. Took to my local garage that is not a MB specialist and he told me DPF blocked, they tried cleaning but would need specialist clean - £490 to remove and clean. So I took the opportunity to buy an IcarSoft and this told me there was an issue with DPF sensor, so removed this, replaced with Bosch sensor and cleaned DPF with some cleaner. This seemed to solve the problem, levels went right down and I checked the regen and that happened at around 300k passively and took numbers back down. Fast forward a couple of thousand miles and EML came back on. DPF is still regenning when it gets to 100% but that is taking 50 miles if that, so its regenning pretty much every day. I have tried the forced regen as believe this burns more soot, but failed to do this, have tried 5 times now and dont intend to try anymore as its quite a long process and doesnt seem to work following the Icarsoft instructions to the letter, seems like quite a few people have had similar issues, as it is regenning anyway - this seems like maybe pointless anyway. So this mornings regen I let finish whilst parked up and did get a lot of whiteish smoke coming from around DPF area, maybe fuel as it uses this to force the process and heat. The car has done 125k miles so maybe the DPF is blocked and just needs a pro clean, sensor readings all seem fine DPF sensor is 0 and goes to 0.04 -0.08 when driving hard, back pressure (i believe EGR) is around 1 bar rising to 4 when driving. No other faukt codes from Icarsoft. So there is a lot of advice on forcing regen, DPF sensors etc - Does anyone know when these things actually fail on w204 2013 OM651 or should they last the life of the car, or have any advice. What I dont want to do is spend the £490 and then still have an issue. I should also say I have seen a slight drop in MPG but nothing significant and could just be age - going from around 55 to 50 on a run
