How can MILES per gallon increase when you are not moving.
There are 2 issues here:
(1) It's not the amount of "miles" that is
increasing, it is the "miles per gallon" value that is
decreasing. The OP said that the fuel
consumption increases, in others words you cover
less miles per gallon.
(2) The mpg value can be seen slightly simplistically as the result of a simple calculation:
C = V / s
with C = consumption in mpg
V=distance covered in miles
s=quantity of fuel used in gallons
Since even at standstil you consume fuel when the engine is running, the amount of fuel increases, in other words while V in the formula remains the same, s increases slightly.
As s
increases, the value of C obviously
decreases for the same value of V, in other words: your fuel consumption for the trip has
increased, shown by a
decrease in the mpg result since you would cover less miles for a given quantity of fuel.
All perfectly logical
![Big Grin :D :D](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f600.png)
