Hi Guys, I am proud owner of an early w203 C180. 2001 with 2 liter engine without kompressor.
I love my car but I have a few problems which I am hoping to solve if not part from my car. Happen to bought it of a very dishonest person anyways.
The problem is when car is cold and started in the morning I get a loud groan from the engine bay. The noise lasts for a few minutes and when car warms up it stops.
Also when you start and drive when cold and stop for example at a traffic light and keep it in D brake foot applied the rev all of a sudden drops then car recovers to normal then 10 seconds later it judders again then back to normal sometimes that droning noise follows the judder but not always. As if all of a sudden it looses electrics. (how ever this is not like rev jump when you have a dirty throttle body as rev doesn't go up and down it gets back to normal position after judder)
I have got a check battery/alternator light coming on occasionally. I have replaced the alternator hoping solve the problem but it hasnt.
I have had a power loss on it about a month ago engine management light came on. restarted the car the car started the run normal but engine management light stayed on. I have got a handheld diagnosis. So scanned it and it said cylinder 4 miss fire. I have cleared the code the light went off and problem hasn't come back. I have been searching for this problem for a few months now but couldnt find any answer. By the way handheld diagnosis doesn't read any faults.
I don't know if this caused by faulty spark plug. Or is it something different. I don't know if the judder and noise and battery problem all related to each other or totally unrelated.
So far what i have done:
I have checked the steering wheel fluid thinking it may be the problem after reading about steering pump could groan if the level is not right it but the fluid is on right on correct level..
I have checked the pulleys on ac compressor, water pump, alternator, steering pump, tensioner but they all turn freely.
The ac on or off it doesn't make any difference.
Hand held diagnosis doesn't read any codes.
For my feeling the car has no performance loss it pulls like a train. Kick down works as it should gearbox goes through all gears. Changing W/S modes in split second.
The cam magnet makes a rattling noise when you start cold and it is leaking.
I know these have problem with oil going in to harness i have sorted it by tinting the harness so oil no longer goes towards ecu. Luckily i caught mine when it was only little and it has stopped going through harness now.
Thank you very much even for reading as i know it has been bit of an essay. If anyone can help me I would greatly appreciate it.
