I have a cl65. When I turn the car off and leave for some time it drops really low on the front passenger side only. Does anybody know what this could be. It raises once you start to drive off. Helpful advice would be appreciated
Just had a local indie have a look at it and nearly fell over,
replace front axle abc valve block
Front axle valve unit
Replace abc oil line for small leak
New abc oil with flush through
Abc oil filter
Mineral oil
Reset via diagnostics
And replace poly V belt tensioner while he is at it as is recc at 37000mls
