i own a 03 e200 and when i press the fob to lock the doors they all lock except for the passenger door also i can only open the boot with the little metal key.anyone ever have this problem and how was it fixed.
it sounds like the door lock is fauly alright,are your number plate bulbs working ?if they are not u have a broken earth wire.the wire breaks on pass side rear boot hinge if you pull back the cover wer the hinge is you'l see a wires
skipperdog,
found the wires ok.would you have any idea which colour code is the earth wire.would it be ok to then cut it and earth it elsewhere.
thanks again
