mbportcul1s
- May 27, 2009
I have a problem starting my 2001 E220 CDi, the problem came on suddenly and not progressively.
You have to hang onto the starter for about 25-30 secs before the engine kicks into life. When started it idles and runs perfectly. Someone has suggested a leaky injector not allowing pressure rail to build up quickly, is this a possibility. Also, I notice there is a sensor with an electrical connection on the end of the pressure rail, is this used to indicate rail pressure and could this be faulty causing same problem.
