Hi guys,
this is one probably for dieselman but any input appreciated.
got a 97 E250 here.. We found diesel leaking from the injector area. All the injector wells were full of diesel.
We thought there was a problem with the leak off pipes so replaced, but it seems that mercedes pipes are thinner than every other make so the universal ones we used just keep popping off.
Anyway, the question is... there seems to be a lot of pressure running through the run off pipes.. is this normal? If not what could be the cause...
Mechanics seem to think maybe blocked injectors, but car runs ok and dont really want to pay £40+ each (and two days) to refurbish the injectors if its not likely to be the problem?!!
Any thoughts anyone??
