Newbie here, and I know you're all going to shout MAF, but just wanted to be precise about the symptons in case anything else springs to mind. My local indy garage thinks it might be but is not sure.
The symptoms are:
- Revs restricted to exactly 2,600 rpm max, lardy power too
- Resets to normal after turning ignition on and off momentarily
- Engine light in cluster remains on
- Occurs around 5-10 miles into a journey until switch off
- Temperature guage reduces slightly (a bar or two) after the fault occurs
- Erratic revs occassionally on half throttle (1.4-1.5k revs)
- Quite a bit of soot if revved hard when able to
If it is the MAF, is it a part I can repair myself? The nuts look to have odd patterns on them. My MAF appears to have A004 153 32 28 on it but can't find one on the Bosch site.
Any help much appreciated.
The symptoms are:
