- Nov 22, 2008
- Location
- Leeds, West Yorkshire
- E280CDI SPORTS ESTATE and C200 KOMPRESSOR SE Coupe Auto (1.8 lit petrol)
It seems like it's the season for auto-trans problems.
After many miles of faultless service my 1998 E300TD is now sticking in various ratios ... Usually when warmed up ... sometimes it's 2nd.
Most often it appears to be 3rd.
Once it's started, it won't change out of this.
Putting the selector into P or N makes no difference.
When it's back in D, the same problem immediately returns.
Switching off and then re-starting sometimes cures it for a short time, but it's soon back.
A couple of things I've noticed.
Reverse still selects OK.
When this condition has occurred, the cruise still works.
However, the speed limiter does not.
Attempting to set the speed limiter gets a set of horizontal lines where the set-speed should be and some bleeps on the warning system.
Is there a speed sensor on the output drive of these 5 speed boxes that the limiter uses ?
Could this be a clue ?
Help please buddies.
I hope it's fixable, as the rest of the car is in reasonable condition for its years and the hard-work it does for me.
Thanks in advance.
J.
Thanks in advance.
J.
