You need very hot soldering iron.
I wouldn't drive, it means lotsa smoke (even in limp mode) and may clogg your DPF
M55 motor may have been behind trouble all the time.
Intake Shut Off Motor Replacement!
www.benzworld.org
Quick fix is put 4,7kOhm resistor in motor plug and test.
Sometimes other boost pressure related fault can be 'cloaked' by another (especially if codes nor read by SDS). And its very usual one fault triggers multiple codes since all are boost related - car sees implausibility between asked and reached pressure, algorithm triggers fault. Simply splitted boost pipe can give anything from turbo to egr via swirl flaps.
Many has done resistor shunt, just be sure connector is well sealed and flaps jammed to open position. SOme put spare motor whirring freely somewhere in engine bay.
I had this problem with the actuator so bought a so called plug and play off ebay. Not long after same happened so firm suggested variable vanes get mucked up in turbo. As they directed i used 2x Forte turbo cleaner as per instructions but I put it into 50ltrs of fuel. Was ok for a while but started doing it again from cold. See my recent post re swirl flap and egr delete. I had turbo refurb via Turbo Dynamics. Can't praise them enough. Dont accept that actuator is plug and play as its not according to Turbo Dynamics. There is a whole lot of muck that runs through these engines. Mine is now cured.Hi All,
I addition to intermittent gear selector problem whereby the gear is not going from Neutral to Reverse unless brake pedal is released (W211 E320CDI 2007 facelift intermittently gets stuck in Drive gear), which now happens very rarely, my car developed another intermittent problem.
About 25% of the time when I start my car from cold the car is underpowered due to a loss of turbo (or so I think). If such loss of power occurs, using manual gear selection enables me to get the car up to any reasonable speed (70mph no problem) - obviously, not as quickly as with turbo, though. When this problem occurs just switching the ignition off and on, even very briefly such as at red traffic lights, more often than not cures the problem. Sometimes the problem occurs even when the car is started warm. Dashboard check engine light appears and disappears (when driven several times without the problem it disappears, then when problems occur several times in succession it reappears).
There is never any juddering. I noticed even when I have this turbo problem it generally appears after about 10 seconds of driving and I have been trying to capture that moment of turbo loss by trying to accelerate heavily for the first ten seconds from start - but was never able to capture the moment.
I had started using Shell Premium Diesel with the view of clearing the systems of various deposits just before this problem started. Switching to Costco Premium Diesel seemed to coincide with reduction in frequency of this problem. Perhaps this is a coincidence, perhaps not.
In the past I had an actuator fault on another E320CDI facelift but there was a lot of juddering shortly after starting a car and turbo-power would be lost only after severe juddering.- and there is no any juddering at all with the present car.
Any thoughts on what could be the problem are welcome! Thanks a lot in advance or any repplies!
quick DIY (assuming connecting rod to passenger side is still solid)
My car has Rough Idle on cold start and No power after...
www.benzworld.org
If connection bars are good, motor spring will keep them open, right.
Sounds like wiring problem, true.
I think wires go to ECU. Wiring diagram would tell which pins.
Is your battery at good health? Low voltage cause gremlins around the car.
Turbo actuator is good 100%?
