Hi
I had a leaking injector a week ago which was replaced by a local garage. The leak was on the exhaust stroke and was producing a soft knocking noise. The garage advised that I should have the remaining 5 injectors reseated; which I allowed them to do.
Problem: A strong smell of diesel from the time I picked the car up from this garage. I assumed this was as a result of spilt diesel just burning off however it is clearly unused diesel.
Took the cover off yesterday and found diesel at the bottom of each injector. If I clear this with absorbent paper then it is quickly replaced by fresh diesel. Car is running OK apart from the smell of diesel. The leak-off pipe appears to be OK. New bolts were fitted as part of the work on the injectors.
Question: Where could this diesel be coming from exactly? Is it the seal between the injector and head?
I look forward to any advice or pointers. Many thanks.
Regards
Ken
Regards
Ken
