Last couple of days I noticed a noise coming from engine bay which almost sounded like the ancillary belt. I took a look when I got home today and noticed some fluid around the bottom of the bay below the radiator and some on the ancillary belt.
At first I thought it was engine oil but once I jacked the car up and took the undertray off I noticed it wasn't black like engine oil. But it was all over the place so looks like it released with some force.
It must be either power steering fluid or transmission fluid.
Do these models have a transmission fluid radiator at the front with pipes carrying the fluid? Or is this most likely power steering fluid? The PSF level reading looks about normal, and doesn't seem low enough to have resulted in the amount of fluid leaked.
There is also a pretty significant noise from what I thought was one of the pump pullies on the NS, but when I was spraying brake cleaner some hit the belt and it temporarily stopped the noise, so almost belt related.
Lastly I also noticed whilst trying to find the source that with the engine running there is a belt tensioner / dampener? which vibrates and moves a lot during running. Is this normal? (I will try and research technical name of this piece and update but it sites behind the turbo boost resonator).
Rough video:
Rough video:
