Morning all,
So last week I did a bit of work on the fuel system by replacing a hose going to the fuel filter, as well as having to replace the injector return line. This meant having to remove the metal fuel pipes to the injectors to reroute the return hose correctly.
After priming the pump a couple of times the car started up and I took her for a 5 min drive, checked no leaks and hoped that was that. Next day and it struggles to start first time and usually starts second time around so I am assuming some kind of air lock in the system.
Is there a method to bleeding the system? I would need to run the engine with the bat wing off to get to the union nuts and kind of reluctant as may get a load of error codes then due to MAF sensors being unplugged etc. Or will the air lock eventually work itself out after a longer motorway drive?
