Kerabo
Well the rubber connection pipe seems to be ok.
As it only pumps from the tank when cranking it’s a bit hard to check the flow so I connected a wire from the pump and to the battery. With the feed to the CIS removed it pumps it’s mainly air and just a little fuel when I connect the pump.
The strange this is the cars owner had drained the tank and put back in 15L of clean fuel.
I would have thought 15L would have been enough to give a supply. Looking at spec reserve is about 12L?
Just a thought but is the reserve a manual switch or does it use it automatically ?
