Hi Guys,
I have a W124 E36 amg estate which I am replacing the head gasket.
The engine timing at tdc shows both sprocket dowel holes lining up with the edge of the head, leaving the inlet cam in its retarded position.
My exhaust sprocket has a "U" mark on one of the two dowel holes. The sprocket is not dowelled on this .
Im not sure whether the head gasket is the original , but at 191k, this might be the second.
My question is.:
Was the factory setting different to the current set up, if the head has been off before.
Should my exhaust sprocket be dowelled using the "U" mark, and if so, how does the timing differ from standard.
Thanks in advance for any replies.
Bob
My question is.:
Bob
