Metalmangler
- May 14, 2015
- Mercedes E220 Estate
Hello all, I have an All Terrain E400 d and like many others I have noticed the crabbing. I would say it's quite bad with Pirelli P Zero run flats. I have to replace the two front tyres and was thinking about Pirelli seal-inside tyres, I'm thinking the side walls will be more flexible than the run-flats and might help the problem, has anyone else tried seal inside, instead of run-flats? The only other problem that I've seen, is once in a while the tickover speed goes from 600 to 800 and the fuel economy drops through the floor, sooner or later it returns to it's old self again. I was told maybe its burning off the particle filter? There is no rhyme or reason to when it starts or stops, it can be fine on stop start journeys then start acting up after a 150 mile journey at around 70 mph. Anyone else seen this?
