[FONT=verdana, arial, helvetica] been wondering where my unadulterated thrust and fuel economy went on my 320 TD, And this long lasting **** about its non existant dump valve the one that Ive been hearing every singal day and that was clearly part of garrete turbo and install by garette and then installed by Mercedes to a DIESEL.
Any way Ive been pressing on and recently decided to clean all the clag off, 5mm worth atleast .. encrusting the valve, and since it was niggling in my mind for the last few months.. and wanted to photograph it for the non believer at large .. any way I used some anti tar and insect stuff and kitchen towl to get all the crap off it ... then I i used some WD40 and spray into the top of the valve where the actuator comes from and press it down which was not happening at first but with some moderate force the leaver eventually made a funny ka-ching noise and it was able to be depress and you could hear air escape and spring/diaphragm squeaking (with car off).
any how since then the economy at thrust is 100% back and no random dumping every time its even 100rpm over 2k rpm it sizzles off a little vent
I'm not sure but I cant remove the valve with out removing the actuator in order to clean it up better.. I'm a bit paranoid to try it, I don't know if it will come out out of top the valve like a pin or something..
but I sprayed it from underneath throughly and let the kitchen towl absorb the ****..
Am i correct in believing there is load of little holes on the bottom of the valve that I might of also unblocked???
I never in 100000 years thought that would affect the car so madly but just the fairly unconnected act of cleaning it solved 3 problems
This also seems to make the trip computer accurate / sensitive
A few days passed and the valve is going black as hell again!
E320 CDI TURBO avantgarde.
[/FONT]
[/FONT]
