Well I have tried the Carlsson Eco (3 versions) and now the Carlsson Power which all failed to do any thing at all. Apparantly mine must be one of the 4% of cars their product doesn't like ?! Shame as they were very plug and play - straight onto the ECU and apparanly do not mess with fuel rail pressure.
Has any one heard of these before, as they also do an 'Eco' version. Both the Dragon and DTE units plug into the Fuel Pressure Transducer on the common rail. Would this mean that fuel rail pressure is adjusted ? or could fuel amounts be set from there?
http://www.dragonperformanceuk.com/store/home.php?cat=537
A more technical pdf on the dragon unit can be downloaded here, (watch the page numbers - they are all over the place !):
http://www.dragonperformanceuk.com/support/index.php?_m=downloads&_a=viewdownload&downloaditemid=4
Any idea where the Brabus units connect to as they look like they have similar connections ?
As others have stated, a remap would be fine but could get written over by Mercedes. Maybe Superchip will bring out their Bluefin for the Mercs - enabling you to change the ECU map yourself.
http://www.mybluefin.co.uk/
Cheers
Adam
Cheers
Adam
