Gnasher141
Took car for 30 minute drive in manual so I kept the revs above 2000 RPM - No green light on button(except briefly on start up) no ECO on dash of any colour(briefly except on start up)
I can do a drop test on the batteries to check them out - keep you postedThen most likely one or both batteries are no longer good enough for Start/Stop, but still OK for starting the engine. Next move? Your call....
The battery in the boot is far from a motorbike battery - this is the one I chargedI'd charge the main battery tbh. It's not all about the motorbike battery .
Not necessarily. My Stop/Start displays similar symptoms to yours - my car is a petrol.The battery in the boot is far from a motorbike battery - this is the one I charged
I’m not concerned at all about the Stop/Start function, in fact I find it quite annoying, it’s more about knowing if it’s injecting more fuel to clean DPF when it goes off.
Exactly the same as mine; cars starts fine after being left for a week, but no S/S and I know it's not holding charge as it should. Given it's the original from 2013 I'm not surprised.If you have the Mercedes Me app the battery status is given on the 'Service' page. On our S205 it showed 'partially charged' at all times ... the car started and ran perfectly, but stop/start didn't work. New battery fitted under warranty - all working fine, and battery status shows 'fully charged'.
The main battery(in boot) was fully charged and a drop test puts the battery under full load indicating the condition. Multimeter test showed 13.4 volts 14.7 volts charge voltage with engine running.As mentioned before, have you charged the main battery ?
Not sure what you mean by drop test but you do need a bit more than a volt meter to fully test a battery's capacity under load.
I'm a bit confused;The main battery(in boot) was fully charged and a drop test puts the battery under full load indicating the condition. Multimeter test showed 13.4 volts 14.7 volts charge voltage with engine running.
When you say full load was that the cranking load on starting the engine ?The main battery(in boot) was fully charged and a drop test puts the battery under full load indicating the condition. Multimeter test showed 13.4 volts 14.7 volts charge voltage with engine running.
Found this in that products questions and answers.
