My car is a 2013 C180 Blue Efficiency. When I bought it the start/stop function worked fine. Then I had a Blackvue camera system fitted to the car and it stopped working. It did actually cut in the other day, by that I mean the Eco symbol on the dash changed from yellow to green and the engine cut out when I stopped at lights. I did have a battery issue after coming back from holiday. The car had been in the driveway for about 3 weeks and the battery had run down. I removed the battery and connected it up to my Optimate 6 charger and at the end of the process it would only reach yellow which on that charger denotes an internal fault. So I bought a new AGM battery and after checking it on the charger fitted it to the car. Just for good measure I also bought and fitted a new AGM auxillary battery. The auxillary battery I removed was put on the charger and took a full charge so it will do as a spare. Could the camera system be putting a drain on the battery and preventing the start/stop from operating? I do mostly short journeys and some have suggested engine temperature could be the problem whilst others say no because theirs works as soon as they set off. Just wondering if anyone has had a similar problem.
