Iskapsts
Just to see if anyone can advise PLEASE.
2 years ago i have bought a very problematic om642.990.
fast forward skip all previous issues,few days ago was fitting back turbo and while fitting back swirl flap motor (passenger side UK) manifold swirl clip just perisshed just turned in ash.
Got 2511-001 code on star,fitted 4.7k res. that cured it, but since durring higher rew drive no problems, but on lower rews i believe under 2k rpm
getting 2355-001- aka p0401 on obd-actuaction of exaust gas recirculation. specified value below range-- folowed by limp mode (turbo off), which can be cured by restart or clear code until ecu ask swirl flaps to shut, mil with egr code is back, driving in town it happens every mile or so.
i read a lot about 4.7k resistor trick and flaps tied in open position no issues for most, why would it generate egr too low flow for me,there is a lot of missinformation on forums how the swirl flaps and egr are conected at some certain low rpm ranges.
i have noticed some boost hiss around intercooler arrea, bet its one of the either side pipes or the intercooler itself busted, i know such a leak can throw of MAF and other readings, but its been there for about 10k miles( dont comment i know i just had 100's of other things to fix.and that pipe on w639 is a pain to access). but as mentioned above it wasnt issue until i fit 4.7k resistor and locked swirl flaps in open position 2355-001 came right away.
Any advice would be much appretiated.
regards igors
regards igors
