egr problems
magentalic
selby east yorkshire
clk 270 cdi
i am still having problems with my c 220 cdi,if i disconnect the plug from the egr it stops the missfire and runs better,the problem is the em light comes on.
my question is if i remove the arm that operates the valve that opens/closes and blank the egr off with a plate.so the egr thinks it is operating correctly but in effect it is not.like peddling a bike without a chain.
should this work,what do you think??
Have you taken the EGR valve off and cleaned it up and checked it is working as it should do?
Removing the arm I doubt will stop it throwing an error.
Not it won't because the MAF will pick up the incorrect readings and throw it into limp mode
i am surprised it has not gone into limp mode now,as it is disconnected
there is a mod that has been used to overcome this, discussed on mb owners club
