Unexpected electrical glitch
On the way home this evening, I had an opportunity to test the kick-down operation, with unexpected results.
As the engine RPM went from approx. 1000 to 5000, the headlights went out, COMAND went off & the car hesitated. Within a second, everything is back to normal except for the new message in the instrument cluster - a red battery symbol and "Visit workshop".
The Memoscan gave the fault code P0563 "System voltage high", which I cleared & hasn't come back. I presume that the glitch was some form of overvoltage protection tripping and resetting.
I shall be measuring the battery voltage tomorrow - I'll build a little adapter to measure the voltage at the cigarette lighter, so I can check it while the engine is running under load.
Do I need to start saving for a new control module, or is it likely to be a software glitch?
The car is a 2005 CLK 500, with about 80K on the clock.
Ian.
Ian.
