Engine codes help needed please
jshodgson
Torquay UK
E class 320 cdi sport 2007
The car (E320 2007) has be running great since having a new EGR and turbo actuator fitted January. Today though it went limp and threw up some codes I hadn’t previously seen. They are: P2032, P2510 both confirmed and P0244 pending
I can’t get it a Star machine at the mo. Any ideas of things I can check first?
By the ways I got no EML when it went into limp mode.
Might be worth a couple of minutes checking engine bay fuse F44 , which covers turbo , inlet port motor etc . Fuse box behind the brake fluid reservoir , should be a blue 15amp .
What mileage are you at now ?
140,000
May well be getting into swirl flap and inlet port motor issues at that mileage
