CHIPZX81
Following on from my previous Q re. overheating probs.
In my previous car (fiat) when the engine temperature reached a certain threshold the radiator fan would start up even if the ignition was turned off at that point, there was no fan belt it was powered direct by an electric motor. The C180(95)'s fan runs with the engine via a belt so if the ignition is turned off so is the fan - right? What role does the thermostat play in all this? I think the thermostat opens up fully at 105 degrees but what does that mean, does the fan run quicker when the thermostat is fully open? I am confused.
