Engine noise... bad!!!
Take the belt off and have a feel of the pulleys, with a bit of luck it should be obvious which one is playing up :thumb:
It is the expensive internal ones that bust the wallet you worry about!
Changed mine, the tensioner and got a great deal from ECP through this club
Belt tensioner or pulley should be easy to identify the culprit, also check SC pulley
Well ive ordered a belt and tensioner, will fit them on monday and hopefully that will be that, otherwise it will be going to the scrappy!
Are you just taking a punt on the tensioner or did you check the pulleys first ?
Taking a punt as the tensioned and belt were only £40 but I will check the other bits and bobs while the belts off anyway... The car was only £800 9 months ago and a rust bucket with a months mot left Now so not too worried about it!
ok... the top "pulley" (with the 4 bolts holding it in) in the picture is the one that is making the noise, upon removing the cover, when you spin it, it goes clockwise and makes a noise, but when you go anti-clockwise, it eventually grinds to a halt.
I take it the engine is kaput?! Thanks again for the help guys.
Not really - that's the water pump, you need a new one.
Hour or two's work and probably £50-100 from ECP/GSF etc.
Should have checked before ordering those bits...:o
Well the belt is all cracked so it will need replacing anyway. Cheers for the help though mate :).
Your lucky your fan isn't attached to water pump. Otherwise you need big spanner and something to hold pump still while you loosen the nut.
Shud be a nice easy job for you and replacing the tensioner at the same time won't do any harm
Well it would be a job for me to do but the mrs has gone out for her friends bday, taken her keys, and cant remember where she put her spare :/!!!!!!
