Oxfordian
Only just saw this - I'll report back!Can,t speak for your specific model but often from around the engine gearbox bellhousing area to nearby chassis leg/ bulkhead-----braided cable or thick black plastic cable[ they can corrode inside] but usually corrosion is at the bolted end connections- may just need a clean/tighten up .
I feel your pain as well as the insecurityUnder normal start conditions you should see the glow plug light before start right?
If so this seems like the exact issue I've been having and am currently stuck at a petrol station. it only ever seems to does it on warm start... leave it a while and then it just goes!! It's driving me bonkers
got it recovered to BS3 formaly know as autospec who had a look and said theyd sorted it....
"strip & check 12v feed & signal to starter, found no signal feed, traced wiring bk to front fuse box and Sam unit.
Plug connector found water ingress. cleaned up connector & refit unit. Tested all ok.
3hrs labour plus vat £234
....drive it home fine, less than 2 hrs later, IT WONT ****ING START. same problem. bk to square one.
Sorry to hear that the issue is still there.got it recovered to BS3 formaly know as autospec who had a look and said theyd sorted it....
Fantastic!Right so I got it going with a jump but noticed it would only jump from alternator current circa 13v and only when I connected to the block and not the negative...
So I took the earth strap off that goes to the chassis from the neg (which looked fine) emmery clothed it up and hey presto ints been fine since!!!
So it seems it was the SAM and the earth.
Tksw203 c200 cdi. so from the neg terminal on the battery their is only one lead comes off the battery and its about 15cm long and goes straight to the chassis
Brilliant! Hope that solves the problem.BREAKTHROUGH >>> after noticing water building up under the SAM I removed the drain in the wheel arch on the SAM side the and the problem is solved. Now 100 percent sure that's what it was!!
Would have though a specialist might have known it was this after telling me the sam had got wet?
well it didn't and after another year of ****ery and random no starts that were always temporarily cured by a jump from a running car (not a jump pack) i found this vid
looks like we are getting to the bottom of it and now at least i dont have to jump it.
