Error Code 9020
jasonyw
Banned
I have a 2005 W211 and with DAS I got the following:
Component M13 (Heating water circulation pump) has Short circuit or open circuit
or Excess temperature. ( If fault code occurs with no complaint reported and no​
malfunctions, erase fault memory and perform a function check. )
How do I fix this problem? :doh:
The pump seemed to be OK as I can switch it on or off with WIS.
Erase the code and wait to see if it happens again.
It came back the same error code.
I believe the coolant has not been changed for 4 years, will it make any different if I change it?
Or has it got to do with the duo valves?
There was a Traffic Master TMC module and I disconnected the power to this module.
Ignore it. It means nothing.
This is the problem with people with DAS and not used to the system. They think there is a fault and there is none. Sporadic fault code always come up esp with the 211.
