I was hoping somebody out there might be able to throw some light (no pun intended) on a problem with my W209 Clk. I've had the whole dash out replacing stepper motors/linkages. Everythings now back together and working. I've got to get the SRS light reset sometime - my understanding is that its latched on (probably because I switched the ignition on with centre console disconnected).
Anyway, all of the disturbed systems have been tested and are working fine. However, when I went out in the car this evening (in the dark) I noticed that all of the upper centre control panel switch backlights (heated seats, hazzard triangle, door lock opener, rear headrest, towing alarm, ESP) are flashing/pulsing at around one flash per second. If I had a bad connection/ground then I would expect the flashing to be more intermittent. Anyone got any idea whats going on here?
Many thanks.
Many thanks.
