Fluid leak help
harryk
N. Ireland
This and that..
Got a fluid leak coming from the 124- can anyone advise on what it is? The fluids only make themselves apparent when car is parked on an incline, strangely. I've attached a pic, but don't know how visible it is- very pale bluey colour. Thoughts?
It could be a coolant leak or windscreen washer fluid leak. You may have a loose hose or a hole somewhere.
info
Could be oil ,or coolant you should know buy checking your levels .Brake fluid, antifreeze, power steering fluid .And engine oil. and automatic fluid if auto.
Could be leaking whatever it is all the time, accumulating in the undertray and only spilling out when parked on an incline. You need to get it checked out I would say.
Harry you may have oil on your under tray and as it rains its washing out on to the road.I used to get it after i have cleaned ny car.But check all fluid levels. You will know if your loosing fluid
