i have a 2001 c220 cdi W203 and i have a brake fluid leak into the foot well. i put this up before and;
" got the master cylinder is leaking into nthe servo and then inside the cabin"
replaced the master cylinder and no change still leaking, have to top up every week or so.
then told its the " clutch master cylinder at the clutch pedal"
Had a look under and that component is bone dry, so not the clutch. When i put my hand up over the brake pedal its wet. there seems ( to the feel anyway) a small cylinder with pipes going to it on the brake pedal, that is wet also. can this be a problem or possible leak? Is it available as a part or is it complete with the pedal?
How difficult is this to fix? im pretty handy but never seen this before.
can anyone shed a bit of light on this and how to fix and what parts i need
Thanks im getting desperate and cant afford to leave with mercedes.
Ron
Ron
