johndugganC
- Jan 8, 2008
I drive a C36 AMG. Today I changed front bulbs to High performance headlight bulbs. For £33 I feel it is a worthwhile upgrade. Lighting is certainly better.
The C36 has foglights (working) in the front under bumper. However when I removed the plastic dipped beam cover from the rear of the headlights I found that the headlight assembly contains a foglight bulb which is wired in BUT NOT working. Is there any way I could wire these to work with the main beam or is this idea a non starter?
Regards, John Duggan, Wales UK.
